Browse Forums Kitchen Corner Re: Fitting in 2 600mm and microwave 25Apr 10, 2015 10:46 pm Hey Leksie, best I can do on my iPad.. Have a look at the posts below from by build thread. Essentially, to the right of the tower you had 3 pantry cupboards, then fridge/freezer. Next to that (so pretty much directly behind where that pic was taken was a 2.5m X 1.5m walk in pantry. Kitchen ended up almost 9m long! Here: viewtopic.php?f=31&t=63391&start=180 Fridges have gone in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ & showing a bit more of the kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18215 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10879 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10049 |
