Browse Forums Kitchen Corner 1 Feb 21, 2015 12:15 am Hi all, If going for handleless drawers - is it better to have a drawer edge with a Sharknose 45 degrees, or square-edge? Or other? Our kitchen designer thinks that square edge are better.... less likely to chip/dirty the thinner edge of the sharknose. Thanks in advance! Re: Handle-less kitchen drawers - square edge or shark nose? 3Feb 23, 2015 3:54 pm MR1600 hi mycl, when you say square edge are you referring to the process of using an aluminium profile rebated into the cabinetry so you can maintain the square edge I am guessing so. Its really a personal preference. If the sharknose is done correctly it shouldn't be an issue. Square edge is quicker and easier for the cabinet maker to do. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Handle-less kitchen drawers - square edge or shark nose? 4Feb 25, 2015 11:36 pm Thanks guys... I guess I'm referring to these diagrams in terms of which is 'best' ... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ In particular options 2 to 5 (5 being the 'sharknose') People all seem to talk about the bevelled 'sharknose' as the in thing ... but out KD thinks that the squarer option 3 would be fine. We are thinking of 2pac satin flat panel finishes... Re: Handle-less kitchen drawers - square edge or shark nose? 5Feb 26, 2015 6:16 am Option 1 - Run away!!! Over time moisture will affect the paint finish and it will crack down in the curved finger groove! Option 2,3,4 - All very similar can be done with any material and the rail can also be done in aluminium. Can feel very agricultural when opening as everything is dead square!! This is not sharknose Option 5 - Sharknose, when done properly there should be a 5mm flat point on the top edge which should resist damage. For me feels the best out of all the options. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Handle-less kitchen drawers - square edge or shark nose? 6Jul 25, 2019 3:25 pm CuttingEdgeKitchens Option 1 - Run away!!! Over time moisture will affect the paint finish and it will crack down in the curved finger groove! Option 2,3,4 - All very similar can be done with any material and the rail can also be done in aluminium. Can feel very agricultural when opening as everything is dead square!! This is not sharknose Option 5 - Sharknose, when done properly there should be a 5mm flat point on the top edge which should resist damage. For me feels the best out of all the options. Hello! I know this is an old post but wanted to know if you think #5 is acceptable for melamine. I don't have a good feeling about 45° cut melamines. Also, very important and the reason I am here. Do you know where can get the complete book of the picture (https://farm9.staticflickr.com/8567/164 ... f2ff_b.jpg) posted by MYCL? I am interested in cabinets construction. Thanks a lot! at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61370 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6349 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 |
