Browse Forums Kitchen Corner Re: laminate vs polyurethane kitchen pantry 2Feb 11, 2015 5:33 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: laminate vs polyurethane kitchen pantry 4Feb 12, 2015 2:28 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: laminate vs polyurethane kitchen pantry 7Jun 30, 2017 8:04 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: laminate vs polyurethane kitchen pantry 10Jan 22, 2018 9:18 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: laminate vs polyurethane kitchen pantry 14Jan 23, 2018 11:12 pm Carcass is generally HMR melamine particle board. The doors and panels are made from MR MDF board that has a very smooth melamine surface. This gives a high quality finish to the 2 pac paint that is applied and also provides the finish to the inside of doors and drawers (no paint) Plywood isn't typically used for cabinetry (unless you specifically want the look) as it's expensive and doesn't give the quality of finish that's achieved on the MDF. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3066 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5202 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44071 |
