Browse Forums Kitchen Corner 1 Feb 02, 2015 7:09 am Hi guys, Wanting advice from those that may know.. Is there much involved in replacing benchtops? I am considering asking our builder to provide kitchen with the most basic of benchtops and then getting a good friend to come in after and replace with nice stone tops. Just looking at options that may save us $$$$ or may cost us more $$$ in the end?? Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Replacing Benchtops AFTER handover?? 2Feb 02, 2015 7:38 am Yes there is a bit involved! First a disconnect and reconnect of plumbing and electrical. You then need to try and get the laminate top out from under the edge of the splashback without damaging it. You then need to work out a solution for a difference in benchtop thickness(assuming you want to keep the splashback) Laminate tops are 33mm thick, stone tops are 20 or 40mm thick. What sort of splashback do you have? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Replacing Benchtops AFTER handover?? 3Feb 02, 2015 7:45 am Not sure how it will finish against the benchtop but we are having a fixed window as our splashback. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Replacing Benchtops AFTER handover?? 4Feb 02, 2015 12:20 pm Roomeat Not sure how it will finish against the benchtop but we are having a fixed window as our splashback. That could make it easier depending on how they finish it. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Replacing Benchtops AFTER handover?? 5Feb 02, 2015 11:00 pm We have our first meeting on Monday to go over the plans. Will ask the questions then. Really just looking at the idea as i am pretty confident I can obtain quality bench tops cheaper than they will. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Replacing Benchtops AFTER handover?? 6Feb 03, 2015 11:08 am Roomeat i am pretty confident I can obtain quality bench tops cheaper than they will. You will be easily able to do it! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Replacing Benchtops AFTER handover?? 7Feb 03, 2015 2:42 pm One option is to ask the builder to only put a single row of standard tiles around kitchen just to meet standards so they can hand over the building than its easy to just remove this single row of tiles and benchtops to install the benchtop and splashback of your choice. Re: Replacing Benchtops AFTER handover?? 8Feb 04, 2015 3:34 pm Splashers One option is to ask the builder to only put a single row of standard tiles around kitchen just to meet standards so they can hand over the building than its easy to just remove this single row of tiles and benchtops to install the benchtop and splashback of your choice. Agreed! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com 2 8442 Yes, get a builder, make sure he is experienced and a registered building practitioner 5 9087 Hi, we live in an area where the black soil is prone to a lot of movement. We have an old 50's house with masonite everywhere and nails popping out, warping, rusted etc.… 0 4614 |
