Hi do any of you have the pull tab type handles? If so would you be able to post a picture of how they look?
Browse Forums Kitchen Corner 1 Jan 28, 2015 11:42 am Re: Pull Tab style kitchen handles? 2Jan 28, 2015 11:47 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pull Tab style kitchen handles? 10Jan 28, 2015 10:14 pm Yes we have a rangehood, unfortunately I don't seem to have a picture of the completed alfresco on this computer. We do get some smoke but it clears fairly quickly as the alfresco is fully open on 2 sides. I hope that helps. Re: Pull Tab style kitchen handles? 11Jan 29, 2015 6:21 am MrBee [what do you mean by 'et them into the edge of the doors and drawers'? im looking at these ones: [] You actually rebate the top edge of the drawer front/door by the thickness of the handle so it sits completely flush. If you don't do this you have to increase the gaps between your drawers from 2mm to 4mm and the chance of scratching/chipping your fronts is increased. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pull Tab style kitchen handles? 15Jan 30, 2015 6:29 am MrBee Pellana no , we must have the 4mm gap Any chance I could bother you for a close up of the gap? Biggest problem with the larger gap is the looks and if the drawer faces sag/settle at all. If they do sag the bottom of the drawer above will touch the handle. It can be easily adjusted. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pull Tab style kitchen handles? 16Jan 31, 2015 9:29 pm Re: Pull Tab style kitchen handles? 17Feb 01, 2015 1:20 pm If you take close note of the first picture above the horizontal gap is at least twice the size of the vertical gap. All gaps should really be the same size. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pull Tab style kitchen handles? 18Feb 01, 2015 8:09 pm First photo (close up) is from a display house, and second one is from our house still in fixing stage. CuttingEdgeKitchen, thanks for your feedback on this. I'll adding this in our PCI checklist to make sure all vertical and horizontal gaps must be equal and all handles must be aligned. Do they change whole door if handle isn't aligned? An extra hole would look awful. Re: Pull Tab style kitchen handles? 19Feb 02, 2015 7:02 am mirz First photo (close up) is from a display house, and second one is from our house still in fixing stage. CuttingEdgeKitchen, thanks for your feedback on this. I'll adding this in our PCI checklist to make sure all vertical and horizontal gaps must be equal and all handles must be aligned. Do they change whole door if handle isn't aligned? An extra hole would look awful. The handle should be recessed into the top edge so its completely flush with the top of the door or drawer. This allows all gaps to be equal. A quality job is always done like this. Unfortunately I don't like your chances in getting it changed/fixed. A lot of companies take the easy way out with these handles and will tell you its how they do them. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 3 4005 The Dulux colour consultants are awesome. If you show them the photos they should be able to figure it out for you straight away 1 1618 |
