Browse Forums Kitchen Corner 1 Jan 22, 2015 9:01 am Looking for recommendations for a non vented rangehood. Something with a reasonable price tag but it as efficient as possible. Our new house build is completely sealed with no roof cavity so there is no option to vent a rangehood to the outside. Any advice? TIA Re: Non Vented Rangehood Advice 3Jan 22, 2015 9:31 am no. cannot be vented to the outside at all as it is a "passiv haus" so completely sealed. Re: Non Vented Rangehood Advice 4Jan 22, 2015 2:22 pm ktotherose no. cannot be vented to the outside at all as it is a "passiv haus" so completely sealed. Which is what? and why cant it be vented?? Recirculating rangehoods are not that good. If you do get one make sure you buy the optional charcoal filter as they don't come with them! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Non Vented Rangehood Advice 5Jan 22, 2015 2:31 pm CuttingEdgeKitchens ktotherose no. cannot be vented to the outside at all as it is a "passiv haus" so completely sealed. Which is what? and why cant it be vented?? Recirculating rangehoods are not that good. If you do get one make sure you buy the optional charcoal filter as they don't come with them! do you have any recommendation for a system with charcoal filter? I know it is not ideal but having something that is vented outside allows for uncontrolled air passage. Passiv haus is a completely sealed house so all air that passes through is completely regulated via a heat recovery unit. Re: Non Vented Rangehood Advice 6Jan 22, 2015 2:47 pm If the system vents to the outside with a non return flap on it does that fulfill the requirements? That way no uncontrolled air can enter the house from outside it can only be pumped out via the rangehood. The only reason I say this is because recirculating rangehoods as has been noted really aren't the ideal option. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Non Vented Rangehood Advice 7Jan 22, 2015 2:50 pm chippy If the system vents to the outside with a non return flap on it does that fulfill the requirements? That way no uncontrolled air can enter the house from outside it can only be pumped out via the rangehood. The only reason I say this is because recirculating rangehoods as has been noted really aren't the ideal option. possibly. I could look into that option. Do you know of any I can look up specs etc? any brands you know of? Re: Non Vented Rangehood Advice 8Jan 22, 2015 5:19 pm ktotherose [. possibly. I could look into that option. Do you know of any I can look up specs etc? any brands you know of?[/quote] Almost all externally ducted rangehoods have a non return flap. Sky is the limit! I think you are overthinking this a little. Go to some appliance shops and have a look at whats available. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Non Vented Rangehood Advice 9Jan 24, 2015 12:55 pm Listen to Cutting Edge... non-vented range hoods expose you to all sorts of nasties. (http://www.nytimes.com/2010/04/01/garde ... .html?_r=0). I work at an energy efficiency laboratory in the US where the scientists call them "forehead greasers." The Passivhaus standard does not call for the house to not exhaust dirty or damp air, but rather that needed makeup air only be allowed in when exhaust fans are operating, and ideally be 'pre-conditioned' (heated or cooled as appropriate). In really efficient systems the makeup air is arranged to exchange heat with the air being exhausted. In the US (where climate extremes are often much greater than in Australia) there's a new industry in powered makeup air units that solve this problem. I'm not sure if air-exchange appliances are available in Australia yet, but if not you can always crack a window. Its better than breathing in cooking vapors. Chris On the threshold of retirement... and trying to check my assumptions at the door Re: Non Vented Rangehood Advice 10Jan 25, 2015 7:53 am Another question, do you have any other exhaust fans in toilets, showers etc? If so how are they treated under the Passivhaus guidelines? I would not have a recirculated system. You can eliminate all the smell even with charcoal because it becomes less effective as it gets dirty...expensive option cheaper to duct externally. Re: Non Vented Rangehood Advice 11Jan 27, 2015 8:11 am Thanks, I think we have it all sorted. Will still have to go ahead with a no vented rangehood, however our heat recovery unit (controlled air exchange) will shift the air to the outside. We will have a vent close to the kitchen and just have to make sure it is on when cooking. Re: Non Vented Rangehood Advice 12May 03, 2018 4:13 pm How are you going 3 years on? We're in the same situation - going with a tightly sealed home using a zehnder HRV. Venting outside is a big problem with tightly balanced HRV homes. Make-up air options are possible but they're far from ideal and bring their own problems. Our architects have been using the Qasair Rangecraft units that have a "plasma" chamber that seems to vaporise the vented air from the rangehood before running it through carbon filters and the re-circulating. They're quite expensive however so I'd love to know if anyone else has seen/used them as the documentation is quite light. Martin Holloday of GreenBuildingAdvisor blog fame has an excellent article on the issue: http://www.greenbuildingadvisor.com/blo ... ange-hoods Re: Non Vented Rangehood Advice 13May 08, 2018 9:53 am taththi How are you going 3 years on? We're in the same situation - going with a tightly sealed home using a zehnder HRV. Venting outside is a big problem with tightly balanced HRV homes. Make-up air options are possible but they're far from ideal and bring their own problems. Our architects have been using the Qasair Rangecraft units that have a "plasma" chamber that seems to vaporise the vented air from the rangehood before running it through carbon filters and the re-circulating. They're quite expensive however so I'd love to know if anyone else has seen/used them as the documentation is quite light. Martin Holloday of GreenBuildingAdvisor blog fame has an excellent article on the issue: http://www.greenbuildingadvisor.com/blo ... ange-hoods No problems at all. carbon filter on the rangehood has been fine. We also have an HRV system. Our house is beautifully comfortable and stable. You won't regret it! Re: Non Vented Rangehood Advice 14May 08, 2018 11:03 am ktotherose taththi How are you going 3 years on? We're in the same situation - going with a tightly sealed home using a zehnder HRV. Venting outside is a big problem with tightly balanced HRV homes. Make-up air options are possible but they're far from ideal and bring their own problems. Our architects have been using the Qasair Rangecraft units that have a "plasma" chamber that seems to vaporise the vented air from the rangehood before running it through carbon filters and the re-circulating. They're quite expensive however so I'd love to know if anyone else has seen/used them as the documentation is quite light. Martin Holloday of GreenBuildingAdvisor blog fame has an excellent article on the issue: http://www.greenbuildingadvisor.com/blo ... ange-hoods No problems at all. carbon filter on the rangehood has been fine. We also have an HRV system. Our house is beautifully comfortable and stable. You won't regret it! Thanks for the reply! Can I ask what brand and model of rangehood you're using? And how well it handles smell depending on what kind of things you cook? Re: Non Vented Rangehood Advice 15May 08, 2018 11:08 am taththi ktotherose taththi How are you going 3 years on? We're in the same situation - going with a tightly sealed home using a zehnder HRV. Venting outside is a big problem with tightly balanced HRV homes. Make-up air options are possible but they're far from ideal and bring their own problems. Our architects have been using the Qasair Rangecraft units that have a "plasma" chamber that seems to vaporise the vented air from the rangehood before running it through carbon filters and the re-circulating. They're quite expensive however so I'd love to know if anyone else has seen/used them as the documentation is quite light. Martin Holloday of GreenBuildingAdvisor blog fame has an excellent article on the issue: http://www.greenbuildingadvisor.com/blo ... ange-hoods No problems at all. carbon filter on the rangehood has been fine. We also have an HRV system. Our house is beautifully comfortable and stable. You won't regret it! Thanks for the reply! Can I ask what brand and model of rangehood you're using? And how well it handles smell depending on what kind of things you cook? Its just a Neff canopy rangehood. Nothing too fancy! Handles smells fine. I really haven't noticed anything different to our previous standard house! From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5522 Thanks. There are plenty of builders around my suburb. I'll make sure to do some door-to-door knocking, or note their building details on the temp fence. 4 4995 Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 10957 |
