Browse Forums Kitchen Corner 1 Jan 22, 2015 12:37 am What is best? Fixed or removable shelving in the butlers pantry? If fixed what height would you do? Does removable look cheap? Or is removable better for flexibility in shelf heights thought pantry? Butlers will house microwave and appliances as well as food stuffs. Re: Shelving Style and Size in butlers pantry 2Jan 22, 2015 6:30 am I'd go fixed. Also - tiered - so you can see what's on the bottom shelves - ie higher shelves are shorter. If they are big - ensure they have enough support. Its amazing what you put in there ... Re: Shelving Style and Size in butlers pantry 3Jan 22, 2015 9:01 am Saint Mike I'd go fixed. Also - tiered - so you can see what's on the bottom shelves - ie higher shelves are shorter. If they are big - ensure they have enough support. Its amazing what you put in there ... if fixed what size would you go? wouldnt you be perhaps limiting the number of shelves possible by fixing? Re: Shelving Style and Size in butlers pantry 4Jan 23, 2015 7:19 am Well - would depend totally on size available and how you intended to use it. Is it a walk in - work at a bench type ? Is it smaller but room for toaster/jug etc. Or just a larger walk in pantry style ? I know people who have their main fridge in the pantry. But this had limited the space in the pantry - imo. Don't think it would limit space. If you have the space you can "waste" some ... ie - if you intend using it as a work area you will need space to move about. You don't want to be cramped in - you wouldn't do this in a kitchen. Not knowing your size - but assuming it is larger than smaller - based on what you have said - I'd go open and good sized shelves. But - top ones have to be tiered - so you can see - unless you plan to use a step ? Are you storing wine on bottom level - floor ? This can be a good idea - often cool. Using those hexagonal pipes But - you don't want to be too cramped. Re: Shelving Style and Size in butlers pantry 5Jan 23, 2015 1:28 pm Saint Mike I'd go fixed. Also - tiered - so you can see what's on the bottom shelves - ie higher shelves are shorter. If they are big - ensure they have enough support. Its amazing what you put in there ... It really depends if its built by a builder or cabinet maker! A builder will just give you a poor attempt and the shelves will need to be fixed. A cabinet maker will have you 100s more options and you can easily have adjustable shelves without problems. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44108 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4204 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5236 |
