Browse Forums Kitchen Corner 1 Oct 20, 2006 12:06 pm hello!
I have just bought a new house and the solid kitchen bench is rotting around the sink area. The 'lines'(?) in the wood are also separating so it looks cracked in some areas. I was hoping someone could advise me on what options i have in resplacing hopefully just the benchtop. We are that handy...and dont have much $$ left at all after paying all those wonderful govt fees when buying a home!! The rest of the kitchen pantry/cupboards are wood also, so im not sure what would match if i just changed the benchtop.. HELP Ali Re: yucky rotting wood kitchen bench! 2Oct 21, 2006 1:52 pm Timber has always been a problem in wet areas and needs to be maintained well so it doesn’t rot.
Laminate will go fine with the timber doors and carcass; I have done many kitchens with this. Laminate would probably be your cheapest alternative. Although if you can scratch together some surpluses funds, I would look into Hi-Max or Corian, they are great. http://www.gunnersens.com.au/products/himacs.htm My person favourite is Quartz, “Ceasar Stone” or “Quarella” But these are dearer still. www.caesarstone.com.au www.quarella.com.au Good luck. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com You will need to replace the entire stairs. Carpenter is the trade you're after. 1 4334 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11675 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5248 |
