Browse Forums Kitchen Corner Re: Overhead cupboard lighting 2Nov 29, 2014 1:25 pm LED strip lights or LED downlights? All cabinets with downlights have a second bottom in them that is rebated to allow for the light and the wiring. Its usually pretty easy to retrofit if there is a power point close by. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Overhead cupboard lighting 4Nov 29, 2014 7:16 pm LD strip lighting can look nice either inset to the bottom of the cabinet right along the back of it but I'm not sure how you retrofit that. Otherwise you can get nice strip lighting lineal metal thing (can't recall proper name sorry) that attaches to base of your cabinets and the strip lighting fits into that. Re: Overhead cupboard lighting 6Nov 30, 2014 10:16 am LED downlights will light up your bench top. LED strips lights are more of a feature rather than actually providing usefull light. Both have there applications. As Beazley77 said you can get an aluminium or plastic chanel to house the LED strip lighting. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Overhead cupboard lighting 8Dec 03, 2014 9:36 pm If you are fitting them afterwards its easy to drill cabinet bottom to insert them and buy a false shelf to hide the wires. If you run the wires around into the rangehood cabinet if you have one and plug into that power point and house your transformers if needed. Re: Overhead cupboard lighting 10Dec 04, 2014 9:18 pm CuttingEdgeKitchens LED downlights will light up your bench top. LED strips lights are more of a feature rather than actually providing usefull light. Both have there applications I beg to differ; with good quality LED strip lights, they will light up your bench very well. Is that bright enough? FWIW, there are no lights between the island bench and the sink, so lighting is exclusively from the LEDs. In this case, to answer the OP, we had the cupboards constructed like a normal handleless cupboard, but with the recess deeper than normal to accommodate the LED lights (they are 8mm high as they are sealed (IP67) and have built-in heatsink along the strip). That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 473 Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16594 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3439 |
