Browse Forums Kitchen Corner 1 Nov 10, 2014 7:22 pm Can anyone please give me some honest feedback about mirror splashbacks? I love the look of them but have been warned of their need of frequent cleaning! Are they very impracticable? how obvious are grease/fingers prints/splashes etc from cooking. Are they easy to clean? What are they like for reflecting sun etc? We have a room with A LOT of windows. Don't want to be blinded while cooking! Thanks, Kirsten Re: Mirror Splashback Reviews 2Nov 12, 2014 6:41 pm Hi Kirsten, I install a lot of Mirror Splashbacks and have had very few complaints. Its kinda like owning a black car or wearing black clothes. They show up more stuff because they are reflective but they look amazing if the rest of your house suits it. All dark colours and reds glass splashbacks are similar that they show up more mess because of the reflection factor. BUT glass is very quick and easy to clean no matter how much mess gets on them. You dont get finger marks as you dont often touch the walls but you see splatters from cooking and around kettles where condensation occurs dust shows up as it sticks to it. If you are the type of person that cleans up every night after cooking than simply wipe it over before washing up and thats it 1 minutes work, and when visitors come over use a spray bottle of water with a touch of metho and polish it up with a microfibre cloth looks amazing and about 5 minutes work. This photo is from a house that had a lot of sunlight, hope this helps Re: Mirror Splashback Reviews 3Nov 17, 2014 2:18 pm Apparently if you have a gas cooktop in front of the splashback it can burn the mirror very easy. I had a couple of people tell me this.... Something I would have never thought of. PIN CRAZY! - http://www.pinterest.com/MrsMorry/ Re: Mirror Splashback Reviews 4Nov 17, 2014 2:35 pm That should never happen if you use the correct glass which is Mirrastar. Unfortunately there are people who will cut corners and use products that are not suitable, but happens in all industries.. Re: Mirror Splashback Reviews 5Nov 18, 2014 1:29 pm Splashers That should never happen if you use the correct glass which is Mirrastar. Unfortunately there are people who will cut corners and use products that are not suitable, but happens in all industries.. Exactly! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Mirror Splashback Reviews 7Nov 26, 2014 5:39 am Crazyk The other thing I've heard complaints is cooktops installed too close to the splashback. Yes this can happen. Standard bench top depth is 600mm and works for most cooktops. Some cooktops position the back burners/elements very close to the outside edge making it hard to put a large pot on. Its a really tough call here as to who is responsible. The cooktop company still makes them to fit into a 600mm top although they don't function correctly nor do they usually give a suggested bench top depth. The kitchen company usually only sees online specs which doesn't indicate burner position properly and doesn't have the suggest bench top depth. If anyone is reading this and about to have a kitchen built, when you select your cooktop take a good long look at the burner position to see if you need to ask for deeper bench tops. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Mirror Splashback Reviews 8Nov 26, 2014 6:59 am The NSW guidelines for gas burners are 50mm from back of cooktop surround to splashback or 200mm from burner to splashback regardless the type of splashback installed. Which if fitted to these specs generally calls for a min 650mm benchtop. This regulation is part of the kitchen and plumbers guidelines, AS/NSZ 4386.2:1996 Re: Mirror Splashback Reviews 10Dec 29, 2014 4:29 pm I love the look of the mirror splashback and our cooktop is on the island so no worries about it. Could anyone tell me about the costs please? Is the mirror splashback more expensive than getting tiles done? Cheers Live Love Lough Building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=74918 Building blog: http://uniquebyeva.com.au/ourhome/ Our food forest blog: http://www.foodforestcookery.com Re: Mirror Splashback Reviews 12Jan 08, 2015 10:06 pm I have a tinted mirror splashback and adore it! Easy to clean with a little metho and water in a spray bottle. As far as cost it was a little over 2k for ours over 4 meters long with return. Site Works 9/5/13 Slab 4/6/13 Frame 4/7/13 Fascia/Gutters 10/7/13 Windows 11/7/13 Roof 24/7/13 Gyprock 13/8/13 Lock up 26/8/13 Bricks 2/9/13 Kitchen 11/9/13 Tiling 28/9/13 Re: Mirror Splashback Reviews 13Feb 15, 2015 1:44 pm The professionals on this thread may know this answer - is it true that a glass splashback will appear wobbly (you notice it when you look at your refection when you walk past it) because it is (or isn't) toughened glass? I was told it was something to do with how it is treated to make it properly heat proof for the cooktop. My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: Mirror Splashback Reviews 14Feb 15, 2015 3:56 pm Toughened Glass has what we call 'roller wave' in the glass due to the toughening process but unless its laying flat out in the sun you can't notice it. The most noticeable glass for roller wave would be the Mirror Splashback but unless you look at it along the face of the glass from the ends and in direct sunlight you won't notice it. We are looking to do a KDR with fairhaven homes, Have seen plenty of good reviews about them pre construction and plenty of negative reviews about them during contruction… 0 18017 Hi starting the process of looking around for Dual Occ builders. Looking to build a home shared with family either as a duplex or front back. Has anyone done any recent… 0 2251 Old Home Restoration / Renovation I cannot find a review for the Reblocker I am getting a quote from. Am I doing something wrong, or are numbers of reblockers who hold VBA registration not reviewed on your… 0 779 |
