Browse Forums Kitchen Corner 1 Oct 07, 2014 1:33 pm My house has a standard island bench that is 850mm wide - 250mm overhang. I requested they widen it to 1000mm. Here is snips from the kitchen elevation: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (Note - no waterfall ends, and the benchtop is 20mm essastone.) I understand they need to provide extra support to the stone. However, I was not expecting to have a void at the back of the cupboards (which seems to be what is drawn) but rather to have a deeper overhang space. Is it possible to do this? Or would I need to add support (extra cabinets facing opposite to the main ones for instance?) Would it be possible to change it post handover? (flooring is being done after handover, so no concerns there) My current thought is to put a narrow cabinet (200mm?) at each end, use those to support a 16-20mm thick panel, that is maybe 50mm narrower than the stone overhang, which in turn supports the stone. Doable? Would I need to replace the backpanel for the island or would it be reusable? DIY job? (good handyman skills... have put-together flatpack kitchens in the past!) Am I strange for wanting to have plenty of knee-space to sit comfortably at the bench? Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Island bench construction question 2Oct 07, 2014 1:48 pm Our builder will not insure an overhang that is more than 300mm, so you may find that your builder has a similar limitation, hence why they've added a void. You could instead request that the drawers are made longer? Re: Island bench construction question 3Oct 07, 2014 4:17 pm trixee Our builder will not insure an overhang that is more than 300mm, so you may find that your builder has a similar limitation, hence why they've added a void. You could instead request that the drawers are made longer? Its actually CaesarStone that wont warrant any overhangs over 300mm. You builder is just passing this along. For overhangs over 300mm the OP will need additional support. There are a number of ways of doing this. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Island bench construction question 4Oct 07, 2014 4:20 pm dragonchild My current thought is to put a narrow cabinet (200mm?) at each end, use those to support a 16-20mm thick panel, that is maybe 50mm narrower than the stone overhang, which in turn supports the stone. Doable? Would I need to replace the backpanel for the island or would it be reusable? DIY job? (good handyman skills... have put-together flatpack kitchens in the past!) Am I strange for wanting to have plenty of knee-space to sit comfortably at the bench? Yes this should work. You could still use the back panel between the cabinets at either end. Just cut it to length. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Island bench construction question 5Oct 07, 2014 5:40 pm Thanks CuttingEdgeKitchens. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11696 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31271 |
