Browse Forums Kitchen Corner 1 Jul 29, 2014 5:37 pm Hi all, I'm interested in getting some opinions on placement of a steam oven + normal oven. They are going to be placed next to the rear bench on the left. ATM, they are side by side, but one of these oven units may be somewhat hidden behind the front door surface of the fridge and pantry. The pro would be that they would both be of ergonomic height. In this kitchen layout however, would it be better to place these in a stack (steam oven on top of oven) from an aesthetic or functional point of view? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Would the more vertical look of a 'tower of ovens' look more balanced or better, than what a configuration with what would appear to be a largely single visible oven? (We are thinking of going for a more stream lined look - handleless, white kitchen with stone benchtops) Would there be much ergonomic difference? Thanks in advance. Re: Steam Oven + Oven Placement - side by side or stacked? 2Jul 29, 2014 5:50 pm I personally wouldn't put them side by side as I believe they are different heights. Oven is probable 596high and steam oven around 460-500mm?? I think it would look strange side by side with them not lining up. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Steam Oven + Oven Placement - side by side or stacked? 3Jul 29, 2014 7:11 pm CuttingEdgeKitchens I personally wouldn't put them side by side as I believe they are different heights. Oven is probable 596high and steam oven around 460-500mm?? I think it would look strange side by side with them not lining up. To circumvent that, we'd probably have to put a warming drawer under the steam oven, to make them match up. Re: Steam Oven + Oven Placement - side by side or stacked? 4Jul 29, 2014 7:54 pm hi I am having my like this ovens, bench with hotplate and ovens but I guest it won't work in yours due to the windows. let me think for a bit Re: Steam Oven + Oven Placement - side by side or stacked? 5Jul 29, 2014 8:01 pm Re: Steam Oven + Oven Placement - side by side or stacked? 7Jul 29, 2014 8:52 pm this is what my ovens will look like. my kitchen should be going in tomorrow if it does I will of cause post a photo. http://i812.photobucket.com/albums/zz47/sharonross13/kitchenovenORANGEwallwhitebulkhead_zps1f5315bf.png the tower on the left has 2 steam combi 45cm each on the right side oven 60cm and warming drawer 30cm Re: Steam Oven + Oven Placement - side by side or stacked? 8Jul 29, 2014 11:04 pm 2-cupcakes-pls this is what my ovens will look like. my kitchen should be going in tomorrow if it does I will of cause post a photo. http://i812.photobucket.com/albums/zz47/sharonross13/kitchenovenORANGEwallwhitebulkhead_zps1f5315bf.png the tower on the left has 2 steam combi 45cm each on the right side oven 60cm and warming drawer 30cm That looks quite good. I presume the red is a wall or backsplash? and the grey upside down T-shape is a rangehood? We are think of having overhead cubboards running across the rear bench, with undermount rangehood. Windows would be not be tall, fitting under the cupboards. Would there be an issue having a cupboard or oven next to the wall on the far side (right side) though? Re: Steam Oven + Oven Placement - side by side or stacked? 9Jul 30, 2014 11:39 am maybe not, it looks like you have a sliding door there. What is that room? we added in pantry's that are 50cm wide next to the oven. in doing so our ovens moved out of the walkway into the larder. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ yes the red is the splash back and the grey thing is going to be the rangehood. Re: Steam Oven + Oven Placement - side by side or stacked? 10Jul 30, 2014 7:04 pm 2-cupcakes-pls maybe not, it looks like you have a sliding door there. What is that room? we added in pantry's that are 50cm wide next to the oven. in doing so our ovens moved out of the walkway into the larder. http://i812.photobucket.com/albums/zz47/sharonross13/finalhouseplans6001_zpsa358bd01.jpg yes the red is the splash back and the grey thing is going to be the rangehood. The bottom sliding door is the chef's pantry... Re: Steam Oven + Oven Placement - side by side or stacked? 11Aug 01, 2014 11:26 am Re: Steam Oven + Oven Placement - side by side or stacked? 12Aug 01, 2014 11:27 am I think your ovens will be fine near your pantry as it's not a mayor walkway Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13724 Move your linen into laundry and access laundry from your present linen space 1 8009 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12283 |
