Browse Forums Kitchen Corner 1 May 30, 2008 8:52 pm Presently in the final stages of fitting the flat-pack kitchen and am now ready for someone to come in to measure up for laminate benches.
Would appreciate if you could advise of someone good on Brisbane\s Northside. Also, is it advisable to get a couple quotes, or isn't there much variance? Re: Brisbane Bench Tops 2May 30, 2008 10:19 pm No idea about tradies in your area.....but always good to get several quotes.....sometimes it's not the dollars but the person that counts.
Are you on the same wavelength....do they listen to you? I've chosen more expensive tradies because I think I'd get along better with some of them..... Also you may pick up different ideas from different people and that may be worth the hassle of a number of quotes. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11696 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31266 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3799 |
