Browse Forums Kitchen Corner Re: 'Touch' activated kitchen tapware - in Australia? 9Jun 25, 2014 11:04 pm Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: 'Touch' activated kitchen tapware - in Australia? 10Jun 25, 2014 11:33 pm Also don't forget that DR brass is needed which apparently requires a separate tooling setup. I think the whole dr brass is a ploy by certain Aussie Manufacturers to restrict the market. Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3035 Thank you fro your response, Simeon. It is good to hear that you have had a positive experience with Parisi. I am always on the lookout for reliable products, and personal… 2 4322 If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26126 |
