Browse Forums Kitchen Corner 1 Jun 03, 2014 4:29 pm Hi folks. Our kitchen is basically a straight line kitchen at the moment with a pantry to the side but we are hoping to install a dishwasher. If we put it next to the pantry like in the below picture, we would gain some much needed bench space but can that happen? I have been reading about how dishwashers are hooked up & it's more complicated than I thought. We have red tounge raised floors and would much rather have pipes going running outside the house than under cabinetry to the sink because if we had any water issues inside the house it would be a disaster zone. We have a steel frame. Can anyone shed some light on how we could do this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ imgupload "A dream you dream alone is only a dream. A dream you dream together is reality" -John Lennon Re: Is a dishwasher possible? 2Jun 03, 2014 4:31 pm Its very easy. The dishwasher pipes run in the kickboard space to inside the sink cabinet and are hooked up to water and waste there. I personally hate dishwashers in the corner at 90degrees to sink cabinets. I would prefer to have the dishwasher where the drawers are in that design. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Is a dishwasher possible? 5Jun 27, 2014 9:37 pm The drawer spot is too narrow for a dishwasher unfortunatley. Thanks all "A dream you dream alone is only a dream. A dream you dream together is reality" -John Lennon Re: Is a dishwasher possible? 6Jun 30, 2014 9:24 am serialstyler The drawer spot is too narrow for a dishwasher unfortunatley. Thanks all Its not if the kitchen is designed properly! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Is a dishwasher possible? 7Jul 04, 2014 11:00 am As above, a quick design consultation with a Kitchen designer would fix that layout up! A Double door fridge also doesn't work too well up against a LH wall, should you need to open it further then 90*. Have you considered switching out the pantry for the hotplate? Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2696 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6633 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36949 |
