Browse Forums Kitchen Corner 1 May 26, 2014 11:00 pm My new galley kitchen was installed last year, I used Dulux natural white 2 pack for the kitchen cupboards doors. My project now is at the end of the galley kitchen is a full length hallway/pantry cupboard. I am converting his cupboard to have normal doors at the top and bottom and in the middle the cabinet maker is putting pivot door slides so that I can put a TV inside the cupboard. I am unsure as to what material the doors should be made of, I thought I could do in the same 2 pack, but as it isn't really part of the kitchen it might look out of place, or I could just use white melamine which might stand out even more. A friend recommend that I just paint it in a semi-gloss paint so it would look like the other doors in the house. Any advice would be much appreciated thanks Re: What material should I use for this cupboard 2May 28, 2014 7:27 am A photo of the area the cabinet will go will help us give you some ideas. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Different to what others have said but thanks for that insight. 2 5197 Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain… 8 10571 |
