Is it more expensive to get a std waterfall bench with mitred joins or just butt joins like in the pic below ( forget about the stepped in shape just a plain waterfall)
Browse Forums Kitchen Corner Re: Waterfall question 2May 15, 2014 4:53 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Waterfall question 4May 15, 2014 8:16 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Waterfall question 6May 15, 2014 8:24 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Waterfall question 9Jul 14, 2014 11:55 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Waterfall question 11Jul 23, 2014 5:39 am http://i763.photobucket.com/albums/xx277/jameshorsburgh/kitchen5_zpsde2de32f.jpg Our 3.5m bench with the mitred joins.............wouldnt even consider butt joins.........The 80mm cost from memory an extra $1.5K over a standard waterfall. Saving money on quality stuff done right firstime Our Build Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=66810&p=1094349#p1094349 thank you! do we need to get this or our builder before we commence new build on the block? 2 10261 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9943 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6137 |
