Browse Forums Kitchen Corner 1 May 15, 2014 12:38 pm I'm planning on having a glass splashback but am wondering how to clean it properly so that it doesn't always look streaky. Does anyone have any advice? Re: Glass splashback cleaning 3May 15, 2014 1:45 pm I have heard metholated spirits for stone so I would imagine the same! White vinegar would also work. Bek and John (and our three kids) Building Verdelho Guest at Haywards Bay see page 167 for floorplan Our blog http://verdehloguest.blogspot.com.au Re: Glass splashback cleaning 4May 15, 2014 1:57 pm Lots of Windex is good or a hand held steamer does an excellent job ... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Glass splashback cleaning 5May 15, 2014 4:55 pm I use a quick spray of standard spray and wipe to cut through the fat/grease and then a final spray of windex to give a streak free look. Windex wont remove the grease well at all! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Glass splashback cleaning 6May 15, 2014 10:39 pm Thanks guys! Do you use a squeegee or just a cloth? Re: Glass splashback cleaning 7May 15, 2014 10:42 pm Does anyone use spray and wipe and then finish with a wipe with an enjo or micro fibre cloth? <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Glass splashback cleaning 8May 16, 2014 8:37 am AKB Does anyone use spray and wipe and then finish with a wipe with an enjo or micro fibre cloth? I use spray and wipe then finish with a quick spray of Windex Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Glass splashback cleaning 9May 16, 2014 8:44 am I clean the splashbacks with glass cleaner but than i have a solution of a little bit of Metho and rest water in a spray bottle from the junk shops and use this along with microfibre cloth to bring out the shine and loose the streaks. Before using the finishing microfibre cloth make sure there is no oil or grease on glass, you can also just use hot soapy water to clean first than use metho mixture. Re: Glass splashback cleaning 11Jul 15, 2014 12:37 am is cleaning glass splash backs harder than cleaning stainless steel splash backs? I have been using stainless steel and I am about to put in glass splash backs for my new kitchen but am worried about the cleaning aspect. Advice appreciated. Re: Glass splashback cleaning 12Jul 20, 2014 10:11 pm Personally I find keeping glass clean is super easy. I either use an enjo cloth with a bit of water or first wipe down with a sponge and detergent and then wipe dry with the enjo. No streaks. I hated keeping sstainless steel streak free. Glass all the way for Me.! Re: Glass splashback cleaning 14Jan 02, 2015 1:48 am I too use Windex but the clear liquid surface cleaner. Find it great for stone bench tops too and avoids me having to store tons of different cleaners. Re: Glass splashback cleaning 16Jan 04, 2015 12:10 am Enjo would work great . The green glove . To take grease off then green micro fibre cloth to dry . But im sure sabco range at bunnings would do the same . Im guess the less water applied the less streaks you will get . No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 5002 |
