Browse Forums Kitchen Corner 1 Apr 25, 2014 7:42 pm I hate the colour of my kitchen cabinets. They are laminex colour "raw linen". I really want something lighter and brighter like laminex colour "parchment". Our cabinetry is polyurethane and only 2 years old. How hard would it be to change the colour? That is what are my options? And would it be expensive? That is am I better to suck it up and wait a few more years until the kitchen has aged? Re: changing colour of polyurethane kitchen 2Apr 26, 2014 11:13 am Are the doors laminex?? or have they been sprayed in polyurethane in the same colour? If its polyurethane you can pull all the doors and drawers off and have them resprayed easily. The hardest part is the end panels. Some are easy but there are some panels that require cabinets to be removed to get them out. Polyurethane is around $80-100sqm to spray if you go direct to the painter. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: changing colour of polyurethane kitchen 3Apr 27, 2014 1:55 pm Thanks so much for the info. We upgraded from laminex to polyurethane. That price isn't too bad but I think we do have a couple of side panels that would be extremely difficult to remove as it is the side of full height pantry that attaches to caesar stone bench and cabinets above and below bench. I think I will look into it further. Re: changing colour of polyurethane kitchen 4Apr 27, 2014 4:13 pm kdgirl That price isn't too bad but I think we do have a couple of side panels that would be extremely difficult to remove as it is the side of full height pantry that attaches to caesar stone bench and cabinets above and below bench. . If you know what you are doing those panels are not that hard to remove. Take your time and remove every screw, cut the silicon seel with a knife and sometime you can loosen the pantry cabinet and move it across slightly to remove the panel. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: changing colour of polyurethane kitchen 5May 17, 2014 11:18 pm Hi kdgirl, My husband runs a French/Polyurethane company in Osborne Park. If you're interested PM me Our Build: viewtopic.php?f=31&t=72518 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3046 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11893 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5525 |
