Browse Forums Kitchen Corner Re: 600mm deep over head cupboards 2Apr 25, 2014 6:01 pm You want overhead cupboards set back so you can lean over the bench without hitting your head. If you do decide to go with deep overhead cupboards though put some lights under the cupboards especially if you just have down lights in the kitchen. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: 600mm deep over head cupboards 3Apr 26, 2014 11:16 am abigail7 I am thinking about having overhead cupboards that are 900mm above bench but are 600 deep. so they stay in line with the cupboards over the fridge and wall oven. Has anybody done this??? NOOOOOOOOO, don't do it. It will look terrible. At 900mm off the bench you probably wont hit your head and it will function ok BUT, you will need a step ladder to get anything and you will be forever loosing things in the back of the cabinets! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: 600mm deep over head cupboards 4Apr 26, 2014 11:53 am Words of wisdom there CEK. I think there is a reason you do not see the overheads the same depth as cupboards and drawers...... As I am vertically challenged I did not even think about the banging your head bit.. My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10870 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17924 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9564 |
