Browse Forums Kitchen Corner Re: Has anyone used Wallpaper with perspex for a splash bac 2Apr 19, 2014 8:50 am Forget Perspex!!!! Use glass! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Has anyone used Wallpaper with perspex for a splash bac 4Apr 19, 2014 10:49 am KGsGirl I can't see why the glass wouldn't work over a wallpapered design. It will work perfectly well as long as the wall is perfectly flat and you can workout how to glue the glass. Normally with a glass splashback the back is sprayed in a colour and then glued to the wall with silicon. You don't have this option if you put the wallpaper on the wall first. Remember it must be toughened glass! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Has anyone used Wallpaper with perspex for a splash bac 5Apr 20, 2014 9:32 pm The issue with the wall paper is the heat as well, even with the glass over it the heat penertrates through the glass and affects the wall paper. The other point is if the wall paper is on the wall and the glass placed in front because perspex can not handle the heat as stated the glass will get condensation behind it from heating up and cooling down and you can not wipe or clean it off. Double glazed windows which are 2 panels of glass are sealed and injected with gas to stop this from happening but you can not do this with this situation. The only true way of achieving this look is to get the glass printed with your design on the back of the toughened glass but this is costly. 4 9061 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15303 As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17869 |
