Browse Forums Kitchen Corner 1 Apr 13, 2014 11:55 am Hi, can anyone give me some pros and cons of either (but not granite). We are thinking of building an investment property for short term holiday let. I would appreciate if it your answer can include things like cleaning, durability, maintenance, price of "standard" vs upgraded color collections... Re: Corian vs stone and quartz benchtops 2Apr 13, 2014 3:22 pm From my understanding Corian scratches a lot easier over quartz, and also Corian isn't as heat resistant. The only plus to Corian would be you can achieve a more seamless look as it won't have a requirement for joins like quartz. I'd say overall the quartz benchtops would be better durability wise. Also, from what I've heard about Corian it has a dull appearance and may look a bit 'plastic'. But I'd say with some colour options available, it may be able to imitate a quartz look. As for Corian colours, you can look here: http://www.thermoform.com.au/corian. But colours would probably depend on the supplier. In regards to pricing, I'm not sure. Re: Corian vs stone and quartz benchtops 3Apr 14, 2014 7:44 am TiredHalo From my understanding Corian scratches a lot easier over quartz, and also Corian isn't as heat resistant. The only plus to Corian would be you can achieve a more seamless look as it won't have a requirement for joins like quartz. I'd say overall the quartz benchtops would be better durability wise. Also, from what I've heard about Corian it has a dull appearance and may look a bit 'plastic'. But I'd say with some colour options available, it may be able to imitate a quartz look. As for Corian colours, you can look here: http://www.thermoform.com.au/corian. But colours would probably depend on the supplier. In regards to pricing, I'm not sure. I agree with everything said above. Corian is normally more expensive than the standard quartz range. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7508 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5659 |
