Browse Forums Kitchen Corner 1 Mar 27, 2014 12:34 am I need some help! I have a rather old D'amani cooktop and a PYE oven. The cooktop is on top of the oven. When I turn on the cooktop or the oven separately, they work fine by themselves. But when I turn them both on at the same time, they both switch off after a couple of seconds. I then have to go to the main fuse box in the house and flick the switch back on. This happens over and over again. I am not sure if the cooktop is faulty or the oven is faulty. Any ideas? And how can I fix this problem? Re: Cooktop and oven help!! 2Mar 27, 2014 1:13 am Call an electrician for a start, something is clearly shorting out and should be looked at. Re: Cooktop and oven help!! 3Mar 27, 2014 7:36 am Its sounds like there is to much load on the circuit when you turn them both on at the same time. It could be a problem with one of the appliances or it could also be that the circuit is overloaded. Only an electrician can tell you. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10876 Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2083 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12518 |
