Browse Forums Kitchen Corner 1 Mar 14, 2014 3:35 pm Hi All Looking for some thoughts and suggestions on what height to have the overhead cupboards at. Our ceilings are 2400mm Ill try put up a picture of the proposed layout but its basically a U shape (Fridge, oven ect on left then stove at end then sink and servery window out on to the deck on the right) Picture now added I have been quoted on the kitchen to be built to 2400mm (with a small 10-20mm shadow line look bulkhead) but as the head height of the Bi Fold servery window is 2100mm im not sure if this will look strange? I like the idea of the extra storage but will i use it well? Thanks Martin Re: Overhead Cupboard Height 2Mar 14, 2014 8:17 pm Why would it look strange?? I think a kitchen at 2100mm would look terrible! I assume you are having square set ceilings?? If so then yes the only way to do it properly is with a 10mm shadow line!! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Overhead Cupboard Height 3Mar 14, 2014 10:35 pm depends on your personal taste. shadowline will look fine, 50 mm bulkheads scribed to the ceiling also look alright or even bulkhead around the same height as kicker scribed to the ceiling. thats basically all the options you have realy. but whatever you do dont do a kitchen 2100 high thats just way to small. Re: Overhead Cupboard Height 4Mar 26, 2014 12:10 pm Go the full height not everything needs to line up with window heights, you probably find that your doorways and windows are different heights too. You may never use the height except to store stuff that you will never use but it will look much much better Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16556 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3435 |
