servery behind kitchen island
starting a new topic because couldnt find anything specific to this.
I am building a house with MJH with and wanted a servery behind the kitchen sink in laminate, not covering the whole island just till where the kitchen sink is as seen in this pic below
http://www.masterton.com.au/Designs/tab ... ad-image-4
Normally MJH do not do something like this, cani get it done after handover, does anyone know any kitchen companies that would do this.
Thanks for you help!!!
We have half our island bench for servery and never use it as everyone just uses the table. We should have made all that area into small cupboards instead of half of it.
A servery is normally higher than your kitchen bench. It usually sits up about 200mm higher and hides the tap and sink.
Hi there, what colour is that splash back? It looks similar to the one I have chosen.
Old Home Restoration / Renovation
Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts
7/08/2023
3
Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or…
6/06/2023
1
No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s
