Browse Forums Kitchen Corner Re: Proposed Kitchen Layout 2Jan 13, 2014 12:04 am Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: Proposed Kitchen Layout 4Jan 13, 2014 4:31 pm Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: Proposed Kitchen Layout - now with dimensions 10Feb 17, 2014 12:58 pm Kitchen Designer @ http://www.diylab.com.au Re: Proposed Kitchen Layout - now with dimensions 11Feb 20, 2014 8:26 am Finally a way to stop those annoying banging blinds! http://www.stopnoisyblinds.com.au Breeze-Ins Pty Ltd 1300 557 803 nathan@stopnoisyblinds.com.au Re: Proposed Kitchen Layout - now with dimensions 12Feb 20, 2014 8:49 am Couple of points. You will have a dead corner which is hard to use. I would switch the door and fridge around so that the fridge is adjacent to the pantry and then the door next to that. I t will allow the bench to continue to the wall and stop. If you move the oven down to where the fridge is you can then move the cooktop along so it provides more bench to the left of the cooktop. This will also allow the cook top to be not directly opposite the sink which is bad feng shui. You will also then have an exact replica of my kitchen except your entry to the laundry is my entry to the scullery. I have a sketch up of my kitchen but will have to provide after work if you want. Cheers Mark Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 8408 You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 15600 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 20931 |
