Browse Forums Kitchen Corner 1 Jan 07, 2014 7:58 pm Hi Jeremy, I am looking into replacing our kitchen benchtop and making it wider. It's currently 3600mm long & 700 wide. I'd like to replace it with a stone but don't know what my options should be given the length as from your previous post it's too long for some stones and that granite could be the best way to go? Do you have an email address or contact number that I can get you on? We are in Sydney too...I can also send you a pic of our current kitchen? I'd still like to keep all the kitchen drawers.... Thanks, Olga Re: 3600mm benchtop needed 2Jan 08, 2014 5:37 am They just join the stone tops to make up the lenght. We have a 4000mm x 900mm ceaser stone kitchen benchtop. Re: 3600mm benchtop needed 3Jan 08, 2014 7:29 am Hi Olga, whos email address are you after? Man made stones don't come any longer than 3200. Most are 3000mm. They can be joined. You might find some granite the length you want. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: 3600mm benchtop needed 4Jan 10, 2014 10:13 am As has been pointed out, most natural stones are not available in this length although it is possible to join two slabs together to make up the length. This has been done in my father's kitchen (although I'm pretty sure that their bench was longer than yours) and you actually cannot tell that it is 2 different slabs unless you are looking closely and have been told where the join is. This is because they had a very good professional come in and undertake the work for them. I recommend contacting someone, like Spaceworks (www.spaceworks.com.au), who does this for a living. Re: 3600mm benchtop needed 5Jan 10, 2014 11:06 am energywindowfashions and you actually cannot tell that it is 2 different slabs unless you are looking closely and have been told where the join is. This is because they had a very good professional come in and undertake the work for them. I recommend contacting someone, like Spaceworks (http://www.spaceworks.com.au), who does this for a living. This is the case with solid surface tops like Corian and Himax but joins in Caesarstone and Granite you will see. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12926 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 |
