Browse Forums Kitchen Corner Re: 3600mm benchtop needed 3Jan 08, 2014 7:29 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: 3600mm benchtop needed 5Jan 10, 2014 11:06 am energywindowfashions and you actually cannot tell that it is 2 different slabs unless you are looking closely and have been told where the join is. This is because they had a very good professional come in and undertake the work for them. I recommend contacting someone, like Spaceworks (http://www.spaceworks.com.au), who does this for a living. This is the case with solid surface tops like Corian and Himax but joins in Caesarstone and Granite you will see. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12912 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6889 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6996 |
