Browse Forums Kitchen Corner 1 Jan 02, 2014 7:15 pm Hi All, Im looking at buying a few 2nd hand pieces of Granite which has been ripped out of a kitchen. It has been broken when taken out, i plan to join these together to make an outdoor BBQ kitchen. As the centre was broken when trying to remove from the kitchen (originally a 3500mm long bench), what is a rough cost for someone to cut these to size? They are 2 pieces of around 1700mm x 500mm, just looking to cut off the break so effectively cut to 1500mm. Also it is glued back up to particle board (melamine?) what is the best way to remove this off the slab without damaging it? Would it need to be removed in order to cut the granite? Re: Granite Bench Question 2Jan 02, 2014 10:07 pm Get a quote from your local stonemason. They are they only people who will have the big diamond blade saw to cut it and the epoxy to glue it back together. 0 9826 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11708 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31279 |
