Browse Forums Kitchen Corner 1 Nov 24, 2013 10:04 am I have this old kitchen tap that is annoying me so badly. I would like to get it replaced but have no idea what to replace it with. My best guess is that it is around 45 years old; was thinking of a kitchen mixer but it wont be in the middle of the sink. Anyone have any examples of what I could replace this with? Want to have some ideas before I call the plumber to discuss it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Old kitchen tap 2Nov 25, 2013 5:55 am There are plenty of online plumbing shops you could also go down to your local tap shop and get some ideas before calling the plumber. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Old kitchen tap 3Nov 25, 2013 6:59 am You could also look at replacing the whole sink. I can't see how big it is though. New mixer etc. Would look good. Otherwise just a new spout and taps. Re: Old kitchen tap 4Nov 25, 2013 1:27 pm Saint Mike You could also look at replacing the whole sink. I can't see how big it is though. New mixer etc. Would look good. Otherwise just a new spout and taps. Those narrow sinks are very hard to find these days. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Old kitchen tap 5Nov 26, 2013 6:25 am A laundry set would fit straight in, it just needs the tap tops & spout unscrewed and the new ones screwed on (with Teflon tape & checking the seat is OK) - just make sure the spout is not too long. If you are as old as the taps ( ), you might like 1/4 turn ceramic - we did and they are great for younger and older folk. Bunnings are good for taps these days, and you can return them if they don't fit. A benefit of ceramic is that it does not use the old seat. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Old kitchen tap 6Nov 26, 2013 10:50 pm ed @ ecoclassic A laundry set would fit straight in, it just needs the tap tops & spout unscrewed and the new ones screwed on (with Teflon tape & checking the seat is OK) - just make sure the spout is not too long. If you are as old as the taps ( ), you might like 1/4 turn ceramic - we did and they are great for younger and older folk. Bunnings are good for taps these days, and you can return them if they don't fit. A benefit of ceramic is that it does not use the old seat. Ed Great advice. I have all mixers in my current house. Apart from the kitchen, next time I will use all 1/4 turn ceramic taps. They are noisier though and don't last as long as you can't change the washers/cartridge. Re: Old kitchen tap 7Nov 27, 2013 6:23 am JB1 ed @ ecoclassic A laundry set would fit straight in, it just needs the tap tops & spout unscrewed and the new ones screwed on (with Teflon tape & checking the seat is OK) - just make sure the spout is not too long. If you are as old as the taps ( ), you might like 1/4 turn ceramic - we did and they are great for younger and older folk. Bunnings are good for taps these days, and you can return them if they don't fit. A benefit of ceramic is that it does not use the old seat. Ed Great advice. I have all mixers in my current house. Apart from the kitchen, next time I will use all 1/4 turn ceramic taps. They are noisier though and don't last as long as you can't change the washers/cartridge. AFAIK, flick mixers are also ceramic. My 1/4 turns don't make a sound other than the flow of water (or maybe I am losing my hearing too)... most have been in about 7 years. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Old kitchen tap 8Nov 27, 2013 6:42 am The better mixers use ceramic cartridges, cheap ones are plastic. I've had 1/4 turn wall tops before and they are definitely noisy. I think its a common trait, but not that bad as there is noise from water splashing anyway Re: Old kitchen tap 9Nov 27, 2013 1:00 pm JB1 The better mixers use ceramic cartridges, cheap ones are plastic. I've had 1/4 turn wall tops before and they are definitely noisy. I think its a common trait, but not that bad as there is noise from water splashing anyway Yes, you are right. Not overly noisy, but I could hear it. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Old kitchen tap 11Dec 02, 2013 10:10 am If space allows you can probably use one of the holes for a mixer tap and cover the other hole with either a tap hole cover or even a detergent dispenser. Just check the tap hole size and the space behind the sink to make sure it can fit a mixer tap. Most mixer taps need a 35mm hole but some can fit in a smaller hole like this one: http://www.quoss.com.au/gooseneck.html For soap dispensers maybe something like this: http://www.ikea.com/au/en/catalog/products/00174241/ that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6736 7 5139 |
