Browse Forums Kitchen Corner 1 Nov 04, 2013 4:00 pm Hi all! Our island bench we are having the waterfall edge We don't want the power point on the waterfall edge and have come up with the idea of using the top draw of the four draw set in the island bench. Are the other ways of having the power point with out placing them on the end ? Re: Power points on Island bench top 2Nov 04, 2013 4:26 pm On the back? Tucked underneath behind the cupboards? Have you seen these? http://www.clipsal.com.au/trade/product ... tches/soho The conceal - the middle and third ones on this page pop down into the bench then pop up when you need them... don't know what they need to do that on the inside of the bench, don't know if they'd be easy or hard or impossible to install in your setup...? Re: Power points on Island bench top 3Nov 04, 2013 8:08 pm Pop up power.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Does the job at the far end of our island bench. You can buy them from Lincoln Senrty http://www.lincolnsentry.com.au/ http://www.lincolnsentry.com.au/media/documents/b0197cfi_evolinebrochure_lres.pdf ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31281 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3806 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13864 |
