I'm a little confused about the thicknesses to choose from.
Originally we thought 40mm but have also been given a quote for 30mm SOLID.
Which is better???
Browse Forums Kitchen Corner Re: Caesar Stone bench top 2Sep 14, 2013 8:10 am Neither! Apples or oranges?? 40mm is 20mm doubled up on the front edges. It is still just as strong. It just depends on which thickness you like. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Caesar Stone bench top 4Sep 16, 2013 6:28 am Evelin stonemason don't like to work with a solid 30mm slab because of the extreme weight. That's not really an issue. 10 years ago everyone was putting solid 30mm granite in there kitchens. My stone masons don't care which thickness you use. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Caesar Stone bench top 5Sep 17, 2013 12:57 pm Hi Netski78, its a personal choice as to what look you prefer. For 40mm I use a stone mason that mitres the front edge (rather than sandwiching two sheets of 20mm together). This way you do not see a line in the front edge of your top. It's ok with some colours, but others the line really stands out. I haven't heard of stone masons not liking 30mm due to the weight before. As 30mm is usually more expensive then 20 or 40mm, I would have thought they would love selling it! Hope this helps With 25 years kitchen experience and a passion for what I do, I have joined this forum to offer advice or at least my opinion on all things relevant to kitchens. I was a cabinetmaker by trade and am now a senior manager of a kitchen company. Re: Caesar Stone bench top 7Sep 17, 2013 2:28 pm Evelin anybody a stonemason? anybody related to one? loads of back problem if you deal with it for many years. Umm ok?????????? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Thankyou for your advice. We do have Caesar coming out and hopefully resolve the issue for us. 4 18728 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31248 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3768 |
