Browse Forums Kitchen Corner 1 Sep 10, 2013 9:50 pm I'm looking at getting a squareform diamond gloss benchtop in white valencia. The only downfall is apparently the corners have to be cut on an angle and edged separately as the laminex cannot be moulded around the corner. I really desire a square look but hesitant to go for the square edge due it been prone to chipping. Has anyone got any ideas on how to have the best of both worlds? Maybe squareform on long sides and square edge on short sides so corner doesn't have to be angled? Re: Help needed for Kitchen Benchtop 2Sep 10, 2013 10:51 pm Just so you are aware, you cant actually squareform (6mm radius postform) diamond gloss. Diamond gloss benchtops are square edged using an acrylic edging that is buffed to a high gloss that matches the laminate. It's 2mm thick so has a very small radius pencil round on the edges. The same edging is used all the way around so there is no need to cut the corners as some do with squareform tops (very old school in my opinion). If you are going to go with a less tight (10mm) post formed top then I would recommend doing as you mentioned with the short ends cut square and laminated. It looks quite ok and is much better than the old 90's look angled corners. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Help needed for Kitchen Benchtop 3Sep 11, 2013 6:09 am Chippy is on the money! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Help needed for Kitchen Benchtop 4Sep 17, 2013 1:18 pm I guess it depends who's doing the post forming. White Valencia in a very tight roll http://i1350.photobucket.com/albums/p77 ... 9babb3.jpg With 25 years kitchen experience and a passion for what I do, I have joined this forum to offer advice or at least my opinion on all things relevant to kitchens. I was a cabinetmaker by trade and am now a senior manager of a kitchen company. Re: Help needed for Kitchen Benchtop 5Sep 17, 2013 2:30 pm It can have cracking issues in the future though. I have seen laminates rolled on a 6mm radius that have cracked two years later. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Help needed for Kitchen Benchtop 6Sep 17, 2013 4:34 pm Just because you can do something doesn't always mean you should. I guess Laminex doesn't recommend Diamond Gloss for square forming for a reason. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12954 You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 17289 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7162 |
