Browse Forums Kitchen Corner Re: Well now I am thoroughly depressed! 21Jul 26, 2013 7:40 am Wow 14K for the kitchen changes! You could build the kitchen for that price. They must be joking! Yes Polytec Createc is prefinished board but it is basically the same as ultraglaze just made by a different company! I would be surprised if they didn't sting you just as badly for Createc. The 9K change to the laundry shouldn't add any more than $3000-4000. They are just ripping you off. It would cost you less to make they changes after handover! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Well now I am thoroughly depressed! 22Jul 26, 2013 11:02 pm One option, which would give you more strength for the same price, is to go with 30mm stone; we found that it was cheaper than 40mm especially if they do it properly with a mitred edge (rather than sticking one slab over another). For a few $K more than your $25K, we got our kitchen, laundry and ensuite done in 30mm Caesarstone with CS splashbacks (kitchen bench 3.1m x 600mm, island bench 3.1x 1.5m, laundry 2m x 600mm, ensuite 2.4m x 500mm). Cupboards above the kitchen bench, drawers below, book-ended with a niche for the fridge one side, and the tower for the ovens (cupboards above, drawers under) as well as 1m wide full height pantry unit (pull out drawers) on the other, plus another similar sized pantry unit, the island having drawers on one side, cupboards on the other, laundry niches for washer and dryer plus an under-sink cupboard, ensuite with 2 cupboards and 5 drawers, all in polyurethane with either push open for drawers and cupboards or soft close for the overhead cupboards. It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9010 Finally got the Soakwell at my house sucked out. Now I’m looking for ideas on how to hide it as it’s a bit of an eye sore. I’m thinking I’d like to turf over the… 0 3274 9 24793 |
