Browse Forums Kitchen Corner Re: Updating a Tassie Oak Kitchen with Caesrstone bench tops 2Jul 08, 2013 7:13 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Updating a Tassie Oak Kitchen with Caesrstone bench tops 4Jul 09, 2013 6:55 am judydg Have a look at Granite Transformations for your bench tops. They use your existing laminate and I think basically put a stone veneer on top. More economical than a full stone bench tops and looks just as good. I have heard very good reports of their work( from the Perth branch - not sure of their reputation in other states) I would do a search on this forum regarding both of the above points before going to much further. Do your research. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11710 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31282 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3808 |
