Browse Forums Kitchen Corner Re: Blum blumotion soft door closers... 22May 07, 2008 8:27 pm oznow I have upgraded all my drawers to use hafele system (40kg). the upgrade only cost about $20 for each drawer, but it comes with soft close mechanism too. lucky! my builder wants $85 +15% + GST Re: Blum blumotion soft door closers... 23May 07, 2008 11:08 pm lol
my drawers cost $3 each for the smaller ones and $6 for the larger ones.... Supplier for these beauties? 25May 23, 2008 10:21 am mattwalker OK so I found the local distributor and got myself some of these things! How f*cken good are they??? Everyone should have these! And cheap...OMG!! $2 for the clip on and $3 for the drill in! Hi Matt, Are you able to let me know where these come from, manufacturer or whatever. Txs Re: Blum blumotion soft door closers... 27Jan 12, 2009 9:22 am Here are two businesses that supply them...don't know where Matt got his from...
http://www.nover.com.au http://www.wilbrad.com.au Cheers, Earl Re: Blum blumotion soft door closers... 28Jan 12, 2009 10:01 pm I got the email ... was just deciding what to do with it... Re: Blum blumotion soft door closers... 29Jan 12, 2009 10:32 pm So, can you fit these if your hinges are NOT Blum (which I'm pretty sure ours aren't, as I can't see 'Blum' embossed anywhere!) ??? Such a great idea - not just fopr ever enthusiastic 4yos, but for overly forceful teen and pre-teen boys, in particular!!! Solidarity, not solidity.......The Lexicon of Life Re: Blum blumotion soft door closers... 30Jan 12, 2009 11:01 pm The hinge ones only fit blum (or copies of) as they clip in to the hole.
The pston style fit anything but are not as good. Re: Blum blumotion soft door closers... 31Sep 07, 2009 12:45 am Just want to share this info: I have fitted the Blum clip on soft close thing onto our "Hettich" hinge and they work perfectly.. No bang anymore.. A pair for $9 from Ikea. Does any one has any idea where I can get the drill-in piston thing for drawer in Perth, WA? Thanks AJ Building with goodlife homes Lock up 24/06/2009 PCI 20/8/2009 Handover 3/9/2009 Re: Blum blumotion soft door closers... 32Jul 18, 2012 4:46 pm Ours are Hettich, but looking at some comparison shots, look almost the same as the blums.. Going to try out two of these to see if they'll work. The Hettich has the same "hole" for the clip, so might be interesting.. Re: Blum blumotion soft door closers... 33Jul 18, 2012 10:38 pm MattyT Ours are Hettich, but looking at some comparison shots, look almost the same as the blums.. Going to try out two of these to see if they'll work. The Hettich has the same "hole" for the clip, so might be interesting.. Our Hettich soft close hinges do not have any clip-on bit; seems to be fully integrated. Re: Blum blumotion soft door closers... 34Jul 19, 2012 7:32 am PHL MattyT Ours are Hettich, but looking at some comparison shots, look almost the same as the blums.. Going to try out two of these to see if they'll work. The Hettich has the same "hole" for the clip, so might be interesting.. Our Hettich soft close hinges do not have any clip-on bit; seems to be fully integrated. Blums hinges are the same now too. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Blum blumotion soft door closers... 35Jul 20, 2012 10:58 pm In case anyone still wants these check them out here: http://www.thecableconnection.com.au/Other--Non-related Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Blum blumotion soft door closers... 37Jul 25, 2012 9:13 pm Do you need the hettich ones? The blum ones fit... Re: Blum blumotion soft door closers... 39Jul 28, 2012 4:25 pm I've asked for soft closing drawers in our kitchen and the builder has quoted $150+ per draw...!!!!! I think I'll add these after handover. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Blum blumotion soft door closers... 40Jul 29, 2012 8:30 am PAB_34 I've asked for soft closing drawers in our kitchen and the builder has quoted $150+ per draw...!!!!! I think I'll add these after handover. It will cost you more to do it after handover! You need completly different runners and drawer boxes and then you have to mount the fronts again. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3320 I personally think pivot door are over the top, as you said a bit impractical having a small useless section and poor insulation. I’m pretty happy with a 920x 2040 with… 1 416 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 |
