Browse Forums Kitchen Corner 1 May 17, 2013 11:16 am I'm struggling with our pantry http://www.edenbraehomes.com.au/a/380.html. The depth is 630mm and 1800mm wide however a blind corner of 50mm is created. The shelving is 400mm, if reducing the shelving to 300mm would it'll still be difficult to reach items on the LHS? I suggested a corner pantry, but the plans have already gone to Basix and windows can not be moved down. After our kitchen appointment I was left disappointed with a lack of solution for the pantry. So far, we've requested the continuation of the bench cutting off the pantry and the microwave will be able to sit on the bench. The pantry will be approximately 1500mm wide and we'll push the fridge over towards the study. The con to this suggestion is the creation of a blind cupboard under bench. The fix is a LeMans, but this reduces the amount of storage. I'm hoping if anyone has a suggestion / solution for a practical use for the pantry. Thanks Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5211 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44077 Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7341 |
