Browse Forums Kitchen Corner 1 May 16, 2013 9:45 pm Hi All, Wondering if I can get your ideas on our kitchen layout. We have just added in another cupboard and overheads at the fridge area in our kitchen. It has been drafted as the fridge next to the pantry with a 600 wide cupboard a the end IYKWIM. Then the lady at the kitchen place pointed out that when we open the fridge, well the freezer side of it on one of the double ones, that it may hit the pantry door handle???? Mainly because pantry is on angle. Should I move the fridge to end of that section and the cupboard next to pantry? Suggestions would be greatly appreciated. Re: Fridge hitting the pantry- Help 2May 17, 2013 12:47 am I had a virtually identical setup in my last house after we renovated the kitchen - side-by-side fridge beside a corner pantry. It wasn't a problem; yes, the freezer door didn't open to the maximum possible swing because the pantry was there but it was still more than ample to access it and pull out the drawers, do defrosting or whatever. I'll note, however, that we did have a deeper than 600 fridge cavity; it was sized specific to our fridge. Probably a good idea to get the manual for the fridge you want to put there; it should have a diagram showing the dimensions and swing of the doors. Copy that diagram then pencil in where the wall and pantry door will be and see how much it impinges - and how much it would need to move to avoid the problem. HD Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Fridge hitting the pantry- Help 3May 17, 2013 8:04 am I am assuming its a left hand hinge?? It should be ok as most fridge doors only need to open to about 130 degrees but you have two options. 1. Reverse the fridge hinge side. Most fridges allow this. 2. As you said move the fridge down and put the cabinet in between. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Fridge hitting the pantry- Help 4May 17, 2013 8:09 am Thanks, French door side by side style. Think it swings about 135degrees. But worried about pantry handle sticking out and it crashing into that. I think we have 800 deep there and if where ever they put cupboard it will only be 600 deep so it will sit back a bit. Trying to visualise it. Re: Fridge hitting the pantry- Help 5May 17, 2013 8:26 am Amancharmar Thanks, French door side by side style. Think it swings about 135degrees. But worried about pantry handle sticking out and it crashing into that. I think we have 800 deep there and if where ever they put cupboard it will only be 600 deep so it will sit back a bit. Trying to visualise it. Oh ok. What is 800 deep? The fridge? Is the cabinet section 600mm deep? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Fridge hitting the pantry- Help 7May 17, 2013 1:51 pm Change pantry door to a concertina-style? (not sure what it would be called) Re: Fridge hitting the pantry- Help 8May 17, 2013 2:16 pm Pantry door would swing open into the fridge if I swapped opening direction so I have the same issue, depending on hinge of course. The area there is 800 deep I think. It is bigger than the standard 600 as the cupboard will have a set back. Another thing I'm not sure about as the fridge will look like it sticks out too much either side. Re: Fridge hitting the pantry- Help 9May 17, 2013 2:34 pm Your plans show the fridge section deeper than the bench tops so I would assume its 800mm deep. How deep is your fridge????? Normally a fridge has to protrude the thickness of the fridge door to allow it to open properly. Make sure you take this into account. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Fridge hitting the pantry- Help 10May 18, 2013 8:40 am We are changing fridges in the new house. We want a Side by side all in one and I think the ones we have looked at are around 800. I realise I need some door swing. Re: Fridge hitting the pantry- Help 11May 18, 2013 9:49 am Is that spare wall to the left of your cupboards? If so why not put the fridge there, then you can have more space for drawers/cupboards where the fridge was meant to be. Regards, Grumbles Re: Fridge hitting the pantry- Help 12May 18, 2013 9:58 am It is, but it is outside the bulkhead and may look a bit outside the room IYKWIM Re: Fridge hitting the pantry- Help 13May 18, 2013 9:58 am Id move fridge to the left and then add cabinets or drawers between pantry and fridge space. Make nib wall between fridge and cabinets 600mm to suit bench width. I would make this your 'coffee zone'. So keep your kettle, coffee machine etc there. Add some overheads to store coffee/tea and mugs in Like this kind thing (sorry couldn't find many images) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Fridge hitting the pantry- Help 14May 20, 2013 10:34 am Can't see the dimensions too clearly, but some options: 1. Add a full length (slim) wine rack between pantry and fridge space. From the little I can see, it looks like there's enough space on the end to do this? 2. Split pantry doors to open inwards (may not work depending on your internal shelving) http://st.houzz.com/fimgs/1fd165610c127 ... itchen.jpg 3. Bifolding pantry doors http://www.handjobhelp.com/images/closet-doors.jpg 4. Open pantry and remove the doors completely. Re: Fridge hitting the pantry- Help 15May 20, 2013 6:59 pm Just realised ours is very similar.... Must look at plans tonight! If this was a major issue.. I spotted a fridge at masters that you can open from either side, however, it's not French doors, just normal. Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5211 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44076 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7545 |
