Browse Forums Kitchen Corner 1 Mar 10, 2013 3:49 pm Hello Everyone, This is my very first post! We have just bought our first home and we are keen to start the renos. The current kitchen has a great layout and I think quite new. All the shelves and cupboards are in perfect condition, soooo I was thinking of replacing the doors, draws and bench top ourselves with some ikea ones. Is that possible? Thanking everyone in advance! Re: Ikea Kitchen? 2Mar 10, 2013 4:19 pm You can also purchase doors, drawer fronts and bench tops from your local cabinet maker. You will have a much larger selection of quality materials too! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Ikea Kitchen? 3Mar 10, 2013 5:36 pm Hi I would have to agree with the previouse reply. You may be better off getting your fronts and benchtop from a local cabinetmaker, as you may have trouble getting the correct sizes from ikea. Their sizing is quite limited, both in width, and certainly the heights of the doors. Ikea's kitchens are modular and come in standard sizing, and require fillers to fit into your room. Worth checking out, though. Erik Bohl Bathrooms BSA: 67641 ABN: 89 250 897 460 Ph: 0437 528 563 Fax: (07) 5577 2173 bohlbathrooms@ymail.com Re: Ikea Kitchen? 4Mar 10, 2013 10:14 pm Even Ikea doors might fit some standard cupboard widths their doors are 70cm high while most Australian kitchen doors are 72cm high. I recently replaced some kitchen doors in a rental property, the width fits perfectly but the Ikea doors are tiny bit too short. I ended up covering the 2cm gap with some aluminium strips. If you really want to use pre-made doors, Bunnings may have more choices in terms of width and height. I did look at Bunnings ones but I didn't have much time as my tenants were moving in in a few days and Bunnings didn't have the material I wanted (I wanted stainless steel to replace some heat-damaged vinyl doors around the cooktop). Re: Ikea Kitchen? 6Mar 11, 2013 12:04 am Ikea's creamy stone-look glossy bench top is so gorgeous, my sister has it, it's so pretty. They have a crappy range of handles and doors though. GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6631 2 4680 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 |
