Browse Forums Kitchen Corner 1 Mar 08, 2013 11:18 am Hi all We are in the process of choosing our benchtops and kitchen layout for our new Porter Davis home. We have a rather large kitchen (long bench against a wall + island bench) and a WIP. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The budget is not stretching for 40mm Caesarstone in all areas of the kitchen and pantry. Even 20mm with a 40mm edge may be pushing it for all of these areas! So I was thinking of doing 20mm Caesarstone in the pantry and on the kitchen bench against the wall... And having 20mm Caesarstone with 40mm edging on the island. Has anyone built a kitchen with 20mm stone on the wall bench and 40mm stone on the island bench or even had varying thicknesses of caesarstone in the kitchen? Do you like it/not like it? Does anyone have any pics or any other ideas? Thanks Re: Different size stone benchtops in the Kitchen 2Mar 08, 2013 12:40 pm There is no such thing as solid 40mm. It is always 20+20mm doubled up. 99% of the time its only the front edge that is 40mm. Yes I have seen 20mm and 40 used together. I personally dont like it but its up to you. FYI my stone mason charges around $600 more to go from 20mm up to 40mm on a standard size kitchen. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 734 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5236 |
