Browse Forums Kitchen Corner Re: Kaboodle 3D Kitchen - Bunnings 2Mar 01, 2013 10:33 am Did you have a look at the minimum system requirements ? Minimum system requirements CPU 1 gigahertz (GHz) equivalent or faster (Intel only) 32MB Graphic card 1024 x 768 Display resolution or higher Broadband Internet connection Operating System: MacOS X 10.6.8 Snow Leopard or 10.7.1 or 10.7.2 Lion Safari 5.1.1 Stewie Re: Kaboodle 3D Kitchen - Bunnings 3Mar 12, 2013 10:55 pm Just a heads up that the kitchen design and the cost it gives you isn't the final cost of your project as it isn't designed to include a lot of the hinges and sliders etc. the best way to do it all is to go in, do the sticker sheet and get them to do the cost up for you. Then it will be accurate and you'll know what it really costs. (I've looked into it myself and my partner works and bunnings) Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Kaboodle 3D Kitchen - Bunnings 4Mar 13, 2013 4:49 pm If you have selected laminate bench tops the price doesnt include the joins either. I have had a number of calls from people asking if I could cut the bench top joins! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kaboodle 3D Kitchen - Bunnings 5Mar 20, 2013 11:02 pm You are buying a cabinet in a box and have to put together yourself. Many people think it just a matter of screwing it together and than attach to wall. Kitchens are not easy to install and the difference between a kitchen guy and DIY at the end is miles apart. If you damage panels of chip them you need to purchase a whole new cabinet. The benchtops come in stock lengths and you will be hard pressed finding someone to do the mitres for them its no easy task. Re: Kaboodle 3D Kitchen - Bunnings 6Mar 21, 2013 7:08 am Splashers You are buying a cabinet in a box and have to put together yourself. Many people think it just a matter of screwing it together and than attach to wall. Kitchens are not easy to install and the difference between a kitchen guy and DIY at the end is miles apart. If you damage panels of chip them you need to purchase a whole new cabinet. The benchtops come in stock lengths and you will be hard pressed finding someone to do the mitres for them its no easy task. Totally agree. I get phone calls from people all the time that are stuck and need help installing there flat pack kitchen. I wont touch it becuase they have usually made many mistakes and it takes ages to sort it out properly. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4774 The gap can be adjusted so it's tighter. You can definitely set up corner cabinets to have the same gap as standard doors. 2 13531 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6623 |
