Browse Forums Kitchen Corner 1 Feb 14, 2013 11:26 am Hi Everyone, I am currently trying to plan out our kitchen in our 1950's weatherboard reno and I only have a small space to work with. 2700mm x 2700mm It is a square area, and I could either do a u shaped kitchen but the fridge would be in an awkward spot or I could do an L shaped with a small island. My question is if I was to go with the island bench option the size would be about 1000mm x 1200mm is this too small? Does anyone have an island of this size and is it functional? There would be no sink or anything in it, just purely bench space and cabinets with overhang. TIA Re: Small kitchen, island bench size 2Feb 14, 2013 12:41 pm It really depends on the layout of your room. Without more information we would be just guessing. But in my experience an island unit in a small kitchen can actually cost you space! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11701 That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 905 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6588 |
