Browse Forums Kitchen Corner 1 Feb 13, 2013 8:03 am Hello, I know this has probably been covered but my search came up blank.. I'm about to sign off my plans but have noticed that the pot drawers I had added to the kitchen are only 400mm deep instead of the full 600mm depth of the bench top. Is this normal? Seems kinda small to me.. The cutlery drawers are also only 400mm but that seems ok for them. Any advice much appreciated! Re: Pot drawers - bench depth 2Feb 13, 2013 12:56 pm Not sure of the depth of mine but two of the cutlery inserts are 520mm deep so add a bit extra for total drawer depth. There is a gas fitting for the stove behind the drawer to its right so the drawer is a bit shorter as the insert is only 470mm deep. Would definitely ask questions before you sign. Regards, Grumbles Re: Pot drawers - bench depth 3Feb 13, 2013 4:35 pm Most kitchen drawers are 500mm deep. 400mm is a bit shallow. Are they in an island unit or have a breakfast bar behind them?? Are you using a spec builder? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pot drawers - bench depth 4Feb 13, 2013 6:08 pm They are against a wall and have nothing behind them that they need to make room for. Quite disappointed if that's the deepest they can be for what they cost... The depth isn't actually noted on the plans it's just me estimating from the picture with a ruler which should be close. Our builder is Redink...just trying to find some kitchens on here now to compare Re: Pot drawers - bench depth 5Feb 14, 2013 5:59 am xxkatxx They are against a wall and have nothing behind them that they need to make room for. Quite disappointed if that's the deepest they can be for what they cost... The depth isn't actually noted on the plans it's just me estimating from the picture with a ruler which should be close. Our builder is Redink...just trying to find some kitchens on here now to compare Ok well if its against a wall and the bench top is 600mm deep the the drawers should be 500mm deep. Make a phone call and ask how deep the drawers are. Everything else is just guessing. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pot drawers - bench depth 6Feb 15, 2013 7:30 pm Hey xxKatxx I was worried about the same thing and it was not something I had noticed until after we had signed off on plans (major internal panic and raised heartbeat ensued!)....Anyway I mentioned it to the cabinetmakers (Coastline Kitchens) and they told me they always do pot drawers as deep as possible otherwise what's the point of having them so I breathed a sigh of relief... Once the kitchen was in I tentatively opened a couple of them and sure enough they are deeper than the cutlery bank...However they are still not 500mm...On the exterior I guess they might be, but i bought some of the inserts from Ikea which are about 510 and they are too small so i will have to cut some off and hope they fit... Amazing isn't it the things that crop up that you don't really give a second thought to, you ask for pot drawers and assume they will be like any other pot drawer you have seen...pffft draughtsmen do this for giggles I reckon! Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: Pot drawers - bench depth 7Feb 16, 2013 5:48 am oneness Hey xxKatxx I was worried about the same thing and it was not something I had noticed until after we had signed off on plans (major internal panic and raised heartbeat ensued!)....Anyway I mentioned it to the cabinetmakers (Coastline Kitchens) and they told me they always do pot drawers as deep as possible otherwise what's the point of having them so I breathed a sigh of relief... Once the kitchen was in I tentatively opened a couple of them and sure enough they are deeper than the cutlery bank...However they are still not 500mm...On the exterior I guess they might be, but i bought some of the inserts from Ikea which are about 510 and they are too small so i will have to cut some off and hope they fit... Amazing isn't it the things that crop up that you don't really give a second thought to, you ask for pot drawers and assume they will be like any other pot drawer you have seen...pffft draughtsmen do this for giggles I reckon! Yes thats right, a drawer depth is taken externally. You then need to deduct the front and back to give the internal depth. 500mm drawer with standard runners gives 467mm internal 500mm drawer with softclose runners gives 484mm internal Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hello I'm remodeling my kitchen and evaluating ideas. We are in the last stages of drawing and I am now considering putting a pot filler tap in above the hob. Has anyone… 0 1367 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27281 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5393 |
