Browse Forums Kitchen Corner 1 Feb 10, 2013 12:33 pm Hi, I am looking at purchasing kitchen sink with two bowls, but there are so many different sizes out there that I am not sure what is a good size. I have been told the bigger bowl the better but it unfortunately it seems to mean that bigger = more expensive. What is the minimum bowl size that everyone recommends? Thanks Re: Kitchen sink bowl size? 2Feb 10, 2013 6:46 pm tweety Hi, I am looking at purchasing kitchen sink with two bowls, but there are so many different sizes out there that I am not sure what is a good size. I have been told the bigger bowl the better but it unfortunately it seems to mean that bigger = more expensive. What is the minimum bowl size that everyone recommends? Thanks HI This is what we are installing Clark Carmel, left hand bowls, right hand drainer. ONE TAP HOLE Deposit on land 20/03/12 Deposit with Builder 01/07/12 Tender signing 12/10/12 Into Council 20/01/2013 Site work started 30/04/2013 Keys 15/11/2013 What can i do tomorrow better then today Re: Kitchen sink bowl size? 3Feb 11, 2013 8:18 am We went double bowl double drainer. If you want to put baking trays in to wash make sure they will fit. Otherwise make sure your laundry sink/trough is large enough fit them. I made sure my roasting pan could fit as i didnt want to have to clean this in the laundry. When i clean the fridge trays i use the laundry trough though. 2 Re: Kitchen sink bowl size? 7Feb 11, 2013 4:03 pm kexkez So you rinse baking trays in a 1/2 sink Mike? Rinse what ... Re: Kitchen sink bowl size? 8Feb 11, 2013 4:05 pm No - seriously ... we have the ones that rinse off pretty easily. I do the roasts and always use a bag. I know what you mean though. A double is a good idea. Re: Kitchen sink bowl size? 9Feb 11, 2013 4:30 pm What material are you using for your bench tops. If its stone I would go for two large bowls and no drainer. Having a second bowl is so handy! With stone you dont have a need for a drainer either. At my house if its just a couple of things we are washing up we let them drip dry in the second bowl on a small in sink drainer. If its a large wash then we have a drying rack with drip tray that lives in the sink cabinet. It sits on the bench and then gets put away. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen sink bowl size? 10Feb 13, 2013 1:04 pm Thanks everyone for your advise, after reading everyones comments, I will probably go for double bowls with no side drainer, and topmount/inset. The one that I have found, that is within budget, is 405x355x205mm deep, my concern is that the 355mm width is not enough? http://www.oliverisinks.com/downloads/s ... SN1064.pdf There is another one that I have seen that isnt exactly the look that I was after (still a topmount but a bit more of a lip) and it is 400x380x200mm, http://www.abey.com.au/wp-content/uploa ... LG2001.pdf Will the extra 300mm per bowl make a big difference, should i sacrifice "the look" for the more practical option? Unfortunately I cant take my large baking dish into try as it is currently in storage thanks again Tweety Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1424 Have had stone benches with undermount sink (kitchen) and drop-in (laundry) and top-mounted basin (bathrooms) for coming up 13 years and not one chip/scratch of any kind.… 2 9680 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7508 |
