Browse Forums Kitchen Corner 1 Feb 09, 2013 11:31 am The standard provision is for a single underbench oven; I want either two or a double. So, what do people think likely to work better? Kitchen layout: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Standard oven wall elevation: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Option 1: (double underbench) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Option 2A: (left side tower) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Option 2B: (right side tower) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They are fairly close to scale. I'm leaning towards a tower, but I'm not sure about having it close to the kitchen entrance or close to the pantry entrance! Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Which oven position? 2Feb 09, 2013 1:14 pm I was leaning towards the side by side under bench but the tower just gives you that much extra draw storage and you can't have too many pot draws. I would go for 2A, keep it flush with the wall in the corner keeping the end beside your pantry door open up top. My kitchen just went in but we have 2 towers and I love them. We have a 60cm oven and 2nd oven/microwave on one side and a coffee machine in the other just to balance out the ends. This has freed the underneath for draws like you will have. Do you have 2 sinks or are you also questioning sink position too? I put ours facing the living so if I am preparing or washing food I can still socialise. Big pantry?- it will be lovely. Blog: http://cbcbuild.blogspot.com.au/ Building Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=62155 Re: Which oven position? 3Feb 09, 2013 4:53 pm Still making up my mind on the sink position - I prefer to have it clear at the wider section but I'm not sure if I want to just shuffle it along a bit or to move it right round to the window. I don't socialise while washing dishes, nor while doing prep if it is at all avoidable. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Which oven position? 4Feb 09, 2013 5:30 pm I'd go for 2B, but 2A would work just as well. I'm a lefty, and so prefer to have the table to the left of the ovens for some reason (I do use knifes with my right hand, though). Anyway, having the ovens up a bit is great, but if one of you are on the small side, be carefull the top one isn't too high up as you want to be able to view what is actually in there and to mitigate the risk of pouring oven hot foodstuff all over your torso. Re: Which oven position? 6Feb 09, 2013 8:48 pm I like 2a and would have had a tower if we had room. Prefer 2a to 2b so pantry entry and the bench top Is left nice and open. It will help give a sense of space I think. We have side by side unde rbench and it works fine but I prefer them to be at eye level. Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Which oven position? 7Feb 10, 2013 6:10 am Where do you intend to put your fridge? Regards, Grumbles Re: Which oven position? 8Feb 10, 2013 10:09 am Default position is inside the pantry - I am considering making that a space for my upright freezer and putting a new fridge niche in the wall opposite the kitchen entrance so I can avoid kids (and certain adults) tramping through the kitchen and getting in my way. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2083 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10865 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6349 |
