Spacing for pendant lights over island bench
Heights - standard height is for the light to finish at 900mm above the benchtop.
Thanks for replying to my posts so you would have them all pretty equally spaced from the left to the right of the island bench. I am still in two minds whether to have the 3 pendants or to have 2 downlights. I would love to hear what others had gone for and why. Also HomeAngels I just looked at your blog and love the colours you have chosen and also might steal that hallway niche idea if my builder wouldn't mind adding that to my list.
Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks
7/08/2023
3
Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or…
6/07/2023
So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus…
