Browse Forums Kitchen Corner 1 Feb 05, 2013 4:53 pm I have noticed alot of people are refering to the material being used for there doors as laminate. In most cases it is not laminate that is being used! Laminate is a product that is around 1mm thick. It is purchased in large sheets and then cut and glued to many different substrates. Alot of doctors surgerys have fully laminated doors but it is vary rare that a kitchen is fully laminated. Laminate doors also have laminate edges that can chip very easily. There is also alot of labour to laminate a door. The product that most people are talking about is Lamiwood(in laminexs range. there are also different names for it by other suppliers) It is a 16-18mm thick MDF sheet with a prefinished melamine coating on both sides. This coating less than 1/4mm thick. The edges applied to this material are 1-2mm PVC/ABS edging. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Its not laminate 3Feb 05, 2013 6:27 pm JB1 It must **** you no end! lol I'm sure people referring laminate as Laminex or reconstituted stone as Ceasarstone must also annoy you, it annoys me and it's not even my line of work. Yep! Its also good for people to know exactly what they are buying! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Its not laminate 4Feb 05, 2013 6:49 pm We will be buying pre-made to measure doors and panels in a crystalgloss finish direct from Laminex as it's 1000's cheaper than going through the builder and the cabinet maker will be installing those (he will provide us the measurements to have them made to). What product is that? Is that Lamiwood? Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Its not laminate 5Feb 06, 2013 6:07 am HomeAngels We will be buying pre-made to measure doors and panels in a crystalgloss finish direct from Laminex as it's 1000's cheaper than going through the builder and the cabinet maker will be installing those (he will provide us the measurements to have them made to). What product is that? Is that Lamiwood? It is very similar to the old Lamiwoods in that it comes in 16-18mm thick large prefinished sheets but has the new crystalgloss finish on the surface. It has ABS edges glue to it after beign cut. Its not a proper laminate. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Its not laminate 6Feb 06, 2013 6:09 am This is taken from the Polytec website MELAMINE doors & panels are scuff and stain resistant and available in a wide variety of Solid Colours and realistic Woodgrains. Polytec manufacture MELAMINE doors & panels in a range of surface finishes, offering Texture, Matt, Ashgrain, Eurograin, Finegrain and Sheen. MELAMINE edge profiles For a traditional solid look, MELAMINE Square Edge doors have 1mm rigid edge on all 4 sides of the door. The MELAMINE door range now gives you the option of clean horizontal lines, minimal detailing together with an architectural colour palette. Our 7 year manufacturers warranty and practical functionality are the hallmarks of the entire polytec door range. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Its not laminate 7Feb 06, 2013 7:34 pm Thanks for the info I love the finish so I'm happy enough that its not proper laminate. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Its not laminate 8Feb 07, 2013 6:13 am HomeAngels Thanks for the info I love the finish so I'm happy enough that its not proper laminate. Thats a good thing though! I would never have fully laminated doors in my kitchen. They chip far to easily. The melamine door with ABS edge is so much better! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Its not laminate 9Feb 07, 2013 8:23 am Thanks for the clarification I was one of the lost souls..cheers. Re: Its not laminate 10Feb 07, 2013 6:47 pm Ohhhh..... I thought you were saying laminate is great. My bad. I should read things properly. Lol. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Its not laminate 11Feb 10, 2013 7:09 am CuttingEdgeKitchens HomeAngels Thanks for the info I love the finish so I'm happy enough that its not proper laminate. Thats a good thing though! I would never have fully laminated doors in my kitchen. They chip far to easily. The melamine door with ABS edge is so much better! Is there a thread with photos (close ups would be good) of these cabinets and edges? I know with the abs edges you can see a line. Would be good to see some installed examples Re: Its not laminate 12Feb 10, 2013 7:40 am I'm fairly sure with the crystalgloss finish they put some sort of sealer on there so you don't see the line?? Here is a pic I took (although a bad one) of the edge of a crystalgloss kitchen. NOTE: due to reflection the corner looks a different colour in this photo but its not like that in real life. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Its not laminate 13Mar 03, 2013 4:57 pm HomeAngels I'm fairly sure with the crystalgloss finish they put some sort of sealer on there so you don't see the line?? Here is a pic I took (although a bad one) of the edge of a crystalgloss kitchen. NOTE: due to reflection the corner looks a different colour in this photo but its not like that in real life. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can't figure out which bit of the kitchen this is! Re: Its not laminate 14Mar 03, 2013 6:55 pm lenarufus [ I can't figure out which bit of the kitchen this is! Drawer front. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18565 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 We are doing heaps of hybrid at the moment and the cost sits between $60-65/sqm including installation. Stairs are around $90-100 each 1 4310 |
