Browse Forums Kitchen Corner 1 Jan 29, 2013 9:17 pm Im about to get my laundry done and want some advice on whether to go vinyl wrap or laminate.i know hundreds of people have issues with vinyl wrap, I was one of them.my kitchen lasted about 4 years before it started peeling around the oven,cooktop,kettle and even the cutlery drawers.was installed in 2004 and now replaced with laminate Now doing the laundry I have the dilemma that vinyl wrap is more resistent to water damage and chipping on the edges or so I've been told.i know there is moisture resistant laminate but nothing's perfect.my mums laminate laundry doors and benchtops started peeling about 15 years in which is a good inning.I know vinyl wrap is a no no in kitchens but is one better than the other for wet area like a laundry.i will have a dryer so I imagine the room gets a little warm Thanks Re: Laundry-which doors vinyl vs laminate 2Jan 30, 2013 6:35 am It wouldnt be proper laminate on the doors. Instead it would be a prefinished door with tough PVC edges. I would use this over vinyl any day. Vinyl is not more resistent to water damage. The material they are both made from are the same except for the thin outer layer. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12390 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8370 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15253 |
