Browse Forums Kitchen Corner 1 Jan 13, 2013 4:26 pm Just designing our kitchen - the one wall is 3m. I am having full height cupboards for this....by the time I take out the 600 oven housing and the fridge and the 600m deep countertop at the corner - I am left with 780 for a pantry ( blind corner) Is that too wide for 1 door - as it is not wide enough really for 2 doors.... Re: width of pantry door..... 2Jan 13, 2013 5:01 pm We had the opposite problem, our fridge space somehow was crazy small and so needed to reduce our pantry door to 620mm to allow us over 1m for our fridge. Was originally a 720mm door. 780 is quite wide - is it an integrated door or a normal door? Integrated (which I wish I had done) won't matter as you can have 2 x 390 doors or 1 x 780mm door like your cupboards full height. If it's a normal door - you could look at a 720mm door and fill up the 60mm gap with a standing wine rack maybe. Bit difficult without the plan - sorry! can you even get a 780 wide door?? Blog: http://cbcbuild.blogspot.com.au/ Building Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=62155 Re: width of pantry door..... 3Jan 13, 2013 5:05 pm it would be a normal door as a pantry, but as it would be the last door before the countertop - it would be a blind pantry. 780 is not a problem size wise as it will be a custom kitchen, but just not sure if it will look too wide Re: width of pantry door..... 4Jan 13, 2013 6:17 pm Sorry - what is the actual door going to be made of - when you say blind pantry are you referring to it as then being the same as whatever your cupboards are made of? If so then no I don't think it will look funny. I have an image when I was looking at kitchens and their blind pantry door was much wider than that and looked good. will see if I can find it and post it.. Blog: http://cbcbuild.blogspot.com.au/ Building Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=62155 Re: width of pantry door..... 5Jan 13, 2013 6:19 pm Lilac Sorry - what is the actual door going to be made of - when you say blind pantry are you referring to it as then being the same as whatever your cupboards are made of? If so then no I don't think it will look funny. I have an image when I was looking at kitchens and their blind pantry door was much wider than that and looked good. will see if I can find it and post it.. Yes the pantry door and the blind panel (over the countertop) next to it will all be the same as the other kitchen cabinets - which will be acrylic - colour undecided ( see my other post) Re: width of pantry door..... 6Jan 13, 2013 6:34 pm Kind of like this?? This looks much wider than 780mm or at least not far off... door closed door open Blog: http://cbcbuild.blogspot.com.au/ Building Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=62155 Re: width of pantry door..... 7Jan 13, 2013 6:38 pm [quote="Lilac"]Kind of like this?? This looks much wider than 780mm or at least not far off... door closed Thanks for that - although it is not a blind pantry - it does give me some idea, and the door is quite wide...thanks Re: width of pantry door..... 8Jan 13, 2013 7:06 pm It is a typical design method to terminate the end of a kitchen with the pantry. I think the position will be just fine. Any bigger and it will start to dominate the space. Mario Re: width of pantry door..... 9Jan 13, 2013 8:42 pm I would never put a hinged door in a kitchen wider then 650mm. If I did I wouldnt warrent the hinges or the door as they wouldnt last long. The door will sag in no time and the hinges would eventually fail. Hinges used by cabinet makers are great but dont like the weight of wide doors. I personally would have two doors but bifold them towards the bench top. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: width of pantry door..... 10Jan 13, 2013 10:16 pm I personally would have two doors but bifold them towards the bench top.[/quote] Thanks for that - the hinges were my concern.. bi fold is something I hadnt considered, but why would you hinge towards the benchtop ? If i am having a blind pantry and therefore want access to the area behind the work\top into the corner...would it not be better to hinge the other way? Re: width of pantry door..... 11Jan 14, 2013 7:37 am chatterbox I personally would have two doors but bifold them towards the bench top. Thanks for that - the hinges were my concern.. bi fold is something I hadnt considered, but why would you hinge towards the benchtop ? If i am having a blind pantry and therefore want access to the area behind the work\top into the corner...would it not be better to hinge the other way?[/quote] The doors open out not in. They would sit flat against the bench top allowing complete access to the entire cupboard including the blind corner part of it. If you hinged them on the other side it would be strange. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: width of pantry door..... 12Jan 15, 2013 5:40 pm CuttingEdgeKitchens The doors open out not in. They would sit flat against the bench top allowing complete access to the entire cupboard including the blind corner part of it. If you hinged them on the other side it would be strange. http://i794.photobucket.com/albums/yy230/VTSS350/BlindCornerPantry_zpsc4d27789.jpg out of curiosity, why wouldn't you have the door hinged on the left side of the cabinet? Re: width of pantry door..... 13Jan 15, 2013 8:39 pm Evelin [\ out of curiosity, why wouldn't you have the door hinged on the left side of the cabinet? Why would you though?? If you put a door on the left hand side then your impeading you access into the pantry. If the door were open you would have to walk around it to get to the pantry. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Thanks again for this information. If you do hear anything different, would be great to know 4 8214 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4096 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5199 |
