Has anyone used a fish tank as a kitchen splashback??
I also thought of a string of lcd panels that could display anything you like including recipes etc as you cook all mounted behind a thick glass wall for protection.
I'm sure someone would have done something similar at some point.
Any other ideas for original/functional splashbacks??
If the fish tank splashback was on an external wall it could be deep enough to be cleaned from outside.
The problems mentioned above can be worked around.
external wall fishtank would in most cases be unsuccessful. One of the main concerns would be larges changes in water temperature, due to direct sunlight.
I am not suggesting the fish tank would be seen from outside!
It would be fully built in and insulated but with a lift up lid allowing axcess to the tank.
Sunlight or heat wouldnt affect this design.
2
Thanks for letting us know. The programmer will have a look at this later today.
19/07/2023
As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining…
